cj7hawk
This is simply false. I use cheap AliExpress 24 AWG wire in my connections, and I test every single one I crimp with a force greatly exceeding the disconnect force, and I've never seen the insulation fail. Not once. (If they fail the test, it's invariably due to a bad crimp.)
Are you telling me that today's cheap wire from AliExpress is somehow of vastly higher quality than the high quality stuff "back in the days"?
Even if you've anecdotally observed great outcomes, I've seen a lot of these fail. Using "more force" to crimp than is correct is more likely in my experience to damage the wire and connector, and can result in it cutting the wire in places and reducing overall clamping and contact area.
If you can't show a datasheet that recommends that the stress be taken by the cables and not the connector when disconnecting a plug, then you're probably using them incorrectly.
If you think about it, pulling a single plug by the wires is probably OK, but the moment you have two or more wires into the same termination, then invariably the stress of pulling two wires, especially if they are ribbon connected, will not tension all of the crimps equally and some crimps will transfer more force into the connector than others simply because it's not possible to get them all exactly the same length when pulling from any point on the cable. That's not a good thing. You'll probably get away with it, and I've done it in a pinch too, but I am very careful when I do it, and if the connector doesn't come loose straight away with minimal force, I stop and reconsider my approach.
The upper section of the crimp is for strain relief, but it's not intended to be a mechanical point for connection and disconnection. That's what the plug is for.
And locks/latches/catches on connectors are to address the possibility that the friction forces on the pin header may not be enough in some situations (eg, when the cables are subject to potential regular forces such as in mobile equipment)
I've pulled many cables in my lifetime, and many times I've ended up with a wire coming out of a crimp - even when the crimps were heavy duty made for arcade machines - not a set of pliers, but a large machine purpose built to crimp a lot of wires.
Perhaps you have personally solved this problem with your technique - I'll credit the possibility - but the rest of the world hasn't yet and when I see a crimped cable I have no idea of it's origin and how well it was crimped.
