I'm bringing my Altair 8800b back to life after 40+ years. I have the unit running with 24K of memory, a 2SIO card and an ACR/SIO-B card. I am able to install and run Basic (started with 4K3.2) by loading it through the 2SIO card and using the appropriate data and loader files from altairclone.com. It's cumbersome in that I have to set the serial port to 9600 8-N-1 to load the software, but then change it to 9600 7-S-1 to run Basic. I could activate the other port on the 2SIO and split it and call it done, but I'd really like to get the ACR working again. (It functioned just fine 40 years ago.) I never knew what the waveforms should be coming out of the demod circuit. Attached is a scope capture of the card playing out 125's recorded from the Altair. The bottom trace is from test point TP (after the filters), and the top trace is the output of the daughter card (signal SRSI). Feeding the front panel the ACR locks up in a second or two every time and the square wave appears solid. My question is "is this what the signal at TP supposed to look like? There is a little bit of clipping at the top but adjusting for that doesn't seem to after the output. When I adjust the two filter pots I can make the 2400 freq equal the 1850 freq, but is that the right approach? Regardless, so far the loads via the ACR all fail.
