fargo
- Joined
- Dec 6, 2019
- Messages
- 215
Hi everyone,
I recently received a GRiD Compass 1101 from a seller who told me that it powers on and that the LCD displays a checkerboard pattern.
Upon receiving the computer, I noticed debris falling from it and heard rattling sounds inside. I removed the top lid and found severe corrosion on one of the monitor hinge bases. I then removed the PSU board and the two upper boards, and unfortunately found heavy battery leakage. The battery was completely disintegrated, and its liquid had attacked every piece of metal in its path. The damage to the bubble memory module shown in the photo appears to be limited to the outer shell, and fortunately the contact pins are still intact.
I cleaned the board as much as I could using IPA, vinegar, and rust remover.
I now want to flip the motherboard over to inspect the other side. The problem is that I could not find a maintenance manual for the Compass 110x series, and I have not been able to figure out how to remove the monitor and keyboard in order to access the motherboard fasteners.
I’m hoping someone here who has experience with these computers can guide me on how to remove the monitor, preferably without releasing the spring tension, and also how to remove the keyboard safely.
Thank you!
Thank you!
