We now have the tool for the job (i.e. the oscilloscope)!
IC2 pin 4 (/HBLNK) at 15.7 kHz looks OK to me.
A couple of things:
1. Why is the Y probe setting at 1.3 V/div? That is a strange number. For measuring digital signals, I would choose 1 V/div - it makes it easy to make measurements using the oscilloscope screen and your eye.
2. The little 'arrow' should be the 0V reference. Before you start taking any measurements, short out the oscilloscope probe tip to the ground clip and adjust the Y position so that it aligns with a major division mark on the oscilloscope screen. This is the 0V point of all measurements you take. Again, it makes life easy (and the measurements more accurate)...
3. If these are as a result of the oscilloscope being set to some AUTO mode. Set it to MANUAL mode. AUTO mode is designed to mess with your head!
IC2 pin 5 (/VBLNK) at 61 Hz looks OK - HOWEVER the voltage is WAY low! I measure (approximately) 2.6 Volts. Whilst this is (technically) a logic HIGH - it is a very poor one! When using an oscilloscope to measure TTL signals, you need to keep in mind the acceptable permissible voltage levels (see
https://learn.sparkfun.com/tutorials/logic-levels/ttl-logic-levels).
IC2 pin 6 (combined) looks OK to me. Note that there is a HIGH when pin 5 (/VBLNK is LOW) and a load of 'mush' when /HBLNK is oscillating. Due to the difference in the frequency of /HBLNK and /VBLNK (15 kHz vs 61 Hz) you cannot see the logic action of the /HBLNK signal (unless you speed up the oscilloscope timebase. The trick to this is to trigger the oscilloscope on a HIGH->LOW transition of /VBLNK on IC2 pin 5 and use the other oscilloscope channel to measure IC2 pin 6. The oscilloscope is now 'locked' to a fixed point in time and you can speed up the timebase to see the detail on IC2 pin 6. You should observe a 15 kHz signal to come into view embedded onto the 61 Hz signal.
The question that you haven't answered is "are these traces stable or not"?
IC20/11, IC20/10 and IC3/4 also look OK.
IC11/8 is ONLY /HBLNK. *** HOWEVER *** this doesn't make sense to me. I am also not sure where /V.GATE is driven from. What signal is on IC11 pin 10 I wonder, and where is it source from?
IC50/10 is ONLY /VBLNK.
-RFSH and -WAIT need to be looked at again in light of my post above.
-RFSH looks good at a period of 2 us - but is this wholly true?
Likewise, -WAIT (with a period of 16 ms) will guarantee DRAM data loss! Is it possible there are some 'little' VBLNK transitions between the HBLNK pulses? If so, the oscilloscope timebase may be running too fast to see them...
