new_castle_j
Thanks to member hmb for all the help so far! I'm still struggling to get a CompuPro 68K machine working and would like any opinions on what to do next. Here's the details.
CompuPro 68K CPU Rev H1
CompuPro RAM 22 256K
CompuPro Disk 1A Floppy ROM version 291D
CompuPro System Support 1 (with "ECO 179" fix and modification to the IC at U28 as described in manual)
Terminal connected to the System Support 1
I have meticulously verified the jumper and switch settings on all cards, I am attempting to boot from 8" floppy disk of CP/M-68K from CompuPro version 1.3
Terminal is set to DTR/DSR handshake, 19.2K baud 2 stop bits per CompuPro manual.
Powering on the machine and hitting reset will cause the floppy drive A to click, click, click, click, like the head is loading track 0 over and over again, but I never see any output on the console.
I think that some code is being read from the disk because I can see the signals change on the serial cable with my RS232 auto-cabler:
Just powering on my terminal only, (S100 is off) I can verify that DTR (20) is asserted
Next I power on the S100 chassis and DSR (6) from the CompuPro goes low
Next I power on the floppy drive, the head loads and the signals change DSR and CTS from the Compupro go high
Then the floppy just goes click click click, loads the head over and over, never seeking to a track.
How should I go about triage on this?
Thank You!
Thank You!
