Other thing I have to ask is: how does one keep the cards from falling out? Seems like they are pretty loose to start with.
The cards will fit snuggly into the slots and make a bit of a snapping sound when properly fit. You will also be able to feel it but it's hard to explain until you've felt it. If you can pull the card out with minimal force, it's not in the slot. Small cards take less force to remove and larger cards more force so it's relative to the card size.
When installing then, first, make sure the card is loosely in place and make sure they are at a perfect 90 degree angle to the slot. Move it back and forth slightly and make sure it's fairly loose. There are card guides that get in the way of the card is not in properly and it will make it difficult to rock the card back and forth slightly if not in place. With the card cage laid flat on a sturdy table , I use two hands and with the palms, I force the card into the slot. It does take a good amount of force but not too much. The CPU card, being a double card unit, takes a good amount of force to fit in. It should be pretty card to come out. A small card takes less force to go in and can be done with one hand. Once they are all in, if you flip the card cage over, nothing should fall out. The square foam pad they used was supposed to provide support but age has made it non-functional.
Thanks for that update. Got the one screw near the power supply. practically EVERY card had fallen out. Managed to hold the double-covered card and the next two to the right of it. The far right card I'm not sure if I reseated it in the right slot but I think I did (took a photo before the cage was lifted.
Take a look at PDF page 30 of this document:
http://bitsavers.trailing-edge.com/...er_Maintenance_Information_Manual_Feb1979.pdf This is a map of the card cage and slot numbers and what cards go where. We'll call this document 1.
Take a look at PDF page 5 of this document:
http://bitsavers.trailing-edge.com/...m_Maintenance_Analysis_Procedures_Jan1979.pdf This has the card part numbers and slot that they fit in. We'll call this document 2.
How to verify:
If you take out a card, you can read the part number off of one of the slot connectors (bottom of the card) but they are really small, hard to read and have more numbers than the part number shown in document 2. You can see this picture with the part number circled in red.
As an example, this is a "Read/Write" or memory card. There can be multiple memory cards and these go in slot "M2" and "N2". Now each of these cards is actually made up of two cards stuck into one card "container" for lack of knowing the proper term. I know it goes into slot "M2" or "N2" as noted in document 1. In this document, you can see the letters along the top of the diagram and the numbers along the side. In this case, it's a full slot card so the "2" of "M2" doesn't really matter as much as the "M" does. You can also see it says "Read/Write" in doc 1. Now, look at the last column noted as "Part Number" on document 2. The first part of the part number on the card will match up with one of the part numbers and fit into the "Location" or slot location of document 1 (in this case one of two slots as there could be two cards). Your system has two cards so they go in slot M2 and N2.
Do this for the rest of your cards. If the CPU card is in firmly, don't take it out. Just verify the location in document 1. Note, when you remove a card, you can see the slot "location" printed on the PCB that lines up with the diagram in document 1. With this information, you should be able to verify the cards and their slot location.
Good luck.
