BitsOfDestiny27
- Joined
- Apr 23, 2025
- Messages
- 7
Hey y’all!
First time posting here, kinda nervous.
Anyways earlier this year I finally got around to collecting vintage computers. Last week, I got an offer I couldn’t refuse for a Compaq Portable (I) for $56, with the carrying case included
Unfortunately, like many of them out there, this unit came in a non-working state. I opened it up and stripped it of its plastic case components (currently drying after a good wash).
Now, I should mention, I don’t have an electrical engineering background, so besides my interest in computers and some personal initiative to learn/study electronics (since last year
), this is truly my first time servicing a computer.
Anyways, with all that jazz, I began my troubleshooting process as follows.
First, I did a “smoke test”, now obviously nothing was going to blow up with the way the PSU was designed to handle bad components. Nothing. The red LEDs of the floppy and hard disk drives blinked for a fleeting moment but that’s it.
Then after opening the unit up, I removed one expansion board at a time, flicking the power switch each time. (this unit came with card no. 3 as a hard disk controller and card no. 4 as an additional LPT card). In each of these tests, the LED on the system board just lit for a second.
Ok, so then I removed the system board. This is where I began to worry about what to test next. I cleaned up the motherboard’s surface in parts with a qtip with IPA and some compressed air (the board wasn’t too nasty but still, some light coating of dust).
Then, I noticed a RAM chip on bank 0 appeared to have corrosion or something weird coming off of one side of it. A picture is attached of it here. I’m curious if a nearby cap caused it but I didn’t see any leaked or anything like that. Plus, I had checked the SAMS photofact sheet and found only tantalum caps were used as electrolytic caps, and if these are manganese oxide caps like the ones on my IBM 5155, then they’d be of the dry type and only blow up, leaving behind some black coating to give it away.
I went ahead and tested the pins of the connector going to the PSU with my multimeter, and this is where I’m not sure I messed up. Using the continuity test, I tested from the black lead on the pins under the ground label on the board, which I believe were like 3-4 pins in the middle, and then used the red lead on the 12V and 5V rails respectively. No beep emitted so I figured there is no short?
I apologize if this doesn’t make a lot of sense, I should’ve taken a picture of my testing but haven’t and probably will in case someone asks.
In any case, the last thing I did was isolate the PSU and test it using the two molex connectors that it used for the (2) FDDs setup. Neither the 12V or 5V showed in the multimeter when testing. I had one molex on the MFM driver that was installed on the unit, and the other molex with the multimeter probes. Then, thinking the MFM was bad, I had a spare bad IDE drive that I had tested for power pefore (power was good, it just spun and made rlly bad sounds). Using that IDE hdd for one molex for a dummy load, the PSU still didn’t output anything above like close to 0V, then falling flat to 0V on both the 5V and 12V rails.
Anyways, I will attach pictures here of the RAM chip, the SAMS photo fact snippet of the electrolytic caps, and what I was able to see of the PSU—a cap that may be bad? I saw NCommander’s video and learned it’s quite tedious to remove the PSU, so before I do, I would like to get input from pros as a checkpoint. I’m sure I made mistakes, or maybe y’all can help me avoid making major ones.
Everyone, at this time thank you for reading my long post, I realize it’s quite long, but adding a bit of background was perhaps necessary in my eyes. Anyways, feel free to reach out to me on Discord as “entropic_dorito” and we can call/message.
Thank you everyone!
Thank you everyone!
