Trixter
Running an MDA monitor at 60Hz is a good way to ruin it.
Were they not rated for 60Hz?
| VCF SoCal | TBD, 2027, | Southern CA |
| VCF East | TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | TBD, 2027, | Westin Dallas Fort Worth Airport |
I know MDA *uses* 50Hz by default but what I was asking was whether or not monochrome/phosphor monitors were *rated* for 60Hz. Meaning, if you drove it at 60Hz, would it release the magic smoke, or is that valid?
I think it's valid, since I have a dim memory of watching VCR output on a monochrome monitor with a composite input.
The CRT itself could run at 60 Hz easily, it's just that the control logic in most MDA monitors isn't multisync, so it can't work on frequencies other than the 50 Hz it's hardwired to. With some modifications to the circuit you could probably use them at 60 Hz on CGA.
Now, a monitor that has both MDA and composite input... I've never seen one, but I wouldn't be surprised they exist.
Another one of my PCs has a Paradise PVC4, which can do exactly the same thing.
Yup, here's the inside of a 5151:It doesn't need to be multisync. 50 vs. 60 Hz refresh rate is such a small difference that it can be easily compensated by adjusting the V-Hold knob on most older monitors and TVs. The IBM 5151 doesn't have a user-accessible V-Hold control, but I'm sure it has a trimpot for it somewhere.
You mean there's some software for PVC4 to control the emulation modes?
Is it available for download somewhere?
I don't think you need to control anything. Set the dip switches to mono, connect an MDA monitor, and when you run CGA software, it should work automatically... and vice versa.
If this card has some special emulation features, there must be some software to enable it, something like SMS.COM for ATI GS/SWGS.
I don't need any software on my ATi Small Wonder either.
Ah, indeed, ATI SWGS has dip-switches to INDEPENDENTLY select the monitor type and software compatibility.
But if you set the dip-switches to mono monitor (18kHz/50Hz) and CGA software compatibility, then you can't run software written for HGC without calling SMS.COM first, can you?
I've seen plenty of so-called "dual" cards (CGA/Hercules), but none of them was able to guess if software intends to use them as CGA or as Hercules, and I doubt if it's even possible.
Prove me wrong, anybody?
My PVC4 works exactly the same way, it has 4 dipswitches on the back.
Any idea what was the algorithm? And did it really work reliably? It all looks very tricky and failure-prone to me...
Still an interesting idea though, nowadays it should be possible to figure out a better algorithm and implement it in a virtual machine like Dosbox.
You mean you can't set mode 7 on a genuine IBM VGA? Works fine with all (almost all?) VGA clones.IBM never chose to make CGA/EGA/VGA support MDA/Hercules-compatible modes
Indeed, I used to use such a setup with stuff like Turbo Pascal and Turbo Debugger, and I accidentally discovered that Scorched Earth game displays some debug messages on the secondary monitor.There is some software out there which uses such a setup (eg SoftICE... there's also an 'easter egg' in the Stars demo by NoooN: if you have an MDA display connected, you can play a game of Snake/Nibbles on that screen while the demo runs on the VGA screen).
True, the virtual machine should have an option to create three windows: MDA, CGA RGBI, CGA Composite.If you're making a virtual machine, you should just emulate both
