wesleyfurr
Does anyone out there have the driver and software for a 200Mb HiFD disk drive? I picked up an internal drive some years ago on ebay (type that is missing the bezel designed to go into an IBM PC), but no disks yet. I recently managed to acquire an external Sony drive on ebay, along with some disks. Unfortunately, the plastic apparently has gotten very brittle and with some less-than-ideal packaging, the case is destroyed at the drive bezel end. Inside appears to be the about the exact same drive as the other I bought previously. Case probably wouldn't have done me much good anyway as it didn't include a power supply or cable, and for who knows what reason (perhaps because of the name "Sony"), the parallel port cable is 25-pin on the PC side and some oddball 44-pin cable on the drive side.
At any rate, thinking about tinkering with it in a machine...guessing some version(s) of Windows may natively support the drive, but a manual I found online for some model talks about software to eject and format the disks, etc. If anyone has a copy, I would be grateful!
Thanks,
Wesley
Thanks,
Wesley
