After a long period with a lot of issues , I am back with new infos : My strange 11/45 is now functionnal and can boot XXDP2.2 XXDP2.5 RT-11 and RSX-11 M . I am really happy to have my system working .
nfire:
What problems I discovered :
When I started to test my RL11 board , the system became instable . I suspected something wrong with the new board but even whithout the RL11 , issues were present. Problems was intermittent. After a long period of tracking , I discovered that some backplane connectors was damaged ! . I was using EDAC connectors , but the quality was poor. The only choice I had was to re build a new backplane with others connectors (I use now Sullins ). Making a backplane need a long time (Lot of soldiers + wire wrapping ).
After that, system came back, but not for a long time
. During DMA Test of RL11, some data was corrupt in memory. The reason was hard to find : the memory board has not been cleaned enough and 2 pins of memory chip was linked by dry soldering flux !!.
Since the system was stable ,I started diagnostics of RL11 . I took a long time , but finally all diagnostics passed !
XXDP 2.2 was functionnal , but none of other
. XXDP2.5 was looping during boot.By exploring boot sequence, I discovered that my system answering to 1 address but it should not ..Easy to fix .
XXDP 2.5 Was now functionnal.
RSX-11M was not booting with a lot of errors messages, and RT-11 Stop in HALT instruction with a PC at very strange address.
I started to analyse source code of RT-11 , trying to follow what happenennig during boot..It was a really hard job !! :shock: . After many weeks of debugging , I discovered that some instructions in CPU didn't set the carry bit correctly ! Instructions was RORB,ASLB,ASRB . I was surprised that CPU diagnostics didn't find these issues !
After fix of instruction implementation, RT-11 was functionnal, and RSX too !
Next step is now to make more tests, finish some improvments in code, and starting thinking about the box and of course making blinkenlights panel !
Comments are welcome...
