advisorability
- Joined
- Sep 6, 2019
- Messages
- 12
I have a Toshiba Tecra 510CDT.
This thing is absolutely perfect for my purpose...playing old games.
I have Debian 3.0 running on it, and I can run Quake 1 using svgalib, without x.org.
I also have a PCMCIA ethernet card and I can ssh with it, surf the internet with w3m, chat on irc, edit files with vim, compile code with gcc, everything I need Honestly I could use it as a workstation at work if I wanted.
I can also run lots of old dos games in FreeDOS.
My only problem: my 2 gig spinning disk is starting to die.
I dumped the contents to my modern Linux desktop with dd, and then again to a 16 gig cf card.
However, the system will not boot from the cf card.
The bios is very rudimentary. No place to enter cylinder info, etc, just boot order selection and that's it.
I know for a fact that these systems can use more than 2 gigs in a disk:
http://www.diaspoir.net/blog/mt/2004/01/toshiba_tecra_510cdt.html
I have tried writing my Debian 3.0 image back to the spinning disk with dd, and it boots fine. I have also tried writing the freedos usb installer image to both the spinning disk and the cf. Boots fine with both from the spinning disk, won't boot either with the CF.
I have tried two different CF to 2.5" adapters also.
So...perhaps I can flash my bios with XTIDE? Or perhaps the CF card needs some sort of special initialization? I'm open to try anything here.
The Tecra has a CD-ROM drive but it won't boot from it. I also have a PCMCIA floppy drive for it but it won't boot from that either. So looks like I'm stuck with just dd and a single hard drive here. (Which works for installing Linux and FreeDOS, but only to a spinning disk)
Thank you!
Thank you!
