giobbi
Hi all,
after a couple of days fighting with some old 5.25" floppy drives and *very* old (and **very** bad) 5.25" floppy disks, I discovered that probably the worst problem using old floppies, is the dust they tend to leave on the floppy drive heads. A single, bad floppy is enough to make your drive useless, until you clean its heads. It took some time to understand that; I believed I was having some troubles with a not reliable drive, but later I discovered that cleaning the heads solved the problem.
So, I had to find a simple way to clean the heads (I mean: avoid to put my fat fingers inside the drive ^_^ ). A cleaning kit would be fine, but those kits costs >15$ plus shipping, and take [eternity^2] to arrive here (thanks to the brazilian custom...). Since problems require solutions, I found a way that works quite fine, easy and for free...
I wrote a guide (well, just a couple of instructions), you can find it there: http://www.verrua.org/cleaning_kit_floppy/cleaning_kit_floppy.htm
I tested this method many times in these two days, and it worked fine and harmlessly.
Hope it can help.
cheers,
Giovi
Hope it can help.
cheers,
Giovi
