cj7hawk
OK, figured out my own questions.
1) It's an issue with the disk detection routines. The Gotek needs an additional "OR" circuit ( functionally a negative AND ) between Motor and Disk Select lines so that it only works when BOTH are low. Introduction of a 74LS32 was suggested, and works OK. Now I can use the Gotek and the CF2 DD drive simultaneously. As I want to be able to read/transfer from CF2, I removed the 720 drive and placed the GOTEK there, so the GOTEK is Drive A now.
2) The images I had were fine, but the detection routines still spook the Gotek into not starting sometimes. So I have to remove the USB and reinsert it at times to make first boot. Then it boots just fine and both drives work. I can't boot from B: though so I can't boot from my CF2 system disks.
3) Locoscript was also being affected by the drive detection, so once I added the extra logic to the Gotek, it started working fine, and lets me save/load from B as well.
I am still looking for;
Any images of the Public Domain software released for this model. I found some other Amstrad PD on archive.org, but not specifically for the 9512. Can anyone offer a suggestion?
Thanks
David.
p.s. The 3D printed Gotek adapter I made up works great. Looks like it was meant to be in there. I just realized there's only few sites that can be used to upload photos, so I'll work out how to get pictures up here.
Thanks
David.
