cj7hawk
Yes, you were correct about this. I don't know why I kept missing it. I think because I was new to all of the programs and constantly moving from one to another (DUF05, DU54, DU90, DiscKit) I couldn't see what was right under my nose, especially since I was so fixated on making sure I only selected A: and B: correctly to avoid accidentially destroying data....
Right now the images are going onto Gotek images in a meta-way and I'm shifting them back to my PC then to copy the PCW created images back to my archive. It's been a long path, but along the way, I found serious bugs with my disk detection routine in my software which was probably corrupting some of the images I was using also.
I've managed to make some significant improvements, and I'm finally starting to see, just a little bit, how CPM comes together... Which is good, because I want to program my own CPM in a new machine I'm building, based on an old one.
Geoff, you've been an incredible help - thank you.
David
David
