How to NorthStar Hard Sector Floppy Transfer to PC with Compaticard II
NobodyIsHere
Hi,
I would like to know if anyone has successfully transferred files from a NorthStar hard sector floppy disk to a PC using a CompatiCard II. If so, would you please explain what and how you did it?
Recently, I obtained a CompatiCard II and it appears according to the COMP.OS.CPM FAQ and another webpage the transfers are possible:
http://www.gaby.de/faq.htm#13
http://www.southernskye.net/IBMPC.html
However, I am a bit unclear on the details of how this is done. What software is required? Uniform/PC? 22Disk? Some other program?
My plan is to get a legacy PC, install the CompatiCard II and any required software and transfer legacy data from the NorthStar Horizon to the PC.
Thanks in advance for your wisdom on the subject.
Andrew Lynch
