I usually try desoldering a chip complete first, sometimes they come out real easy and some can be real stubborn, In which case i will slice through the stubborn legs with a small rotary disc cutter (Space permitting) or use a good pair of snips.
Trixter said:I will likely desolder, without regard to saving the original part. I know cutting it would be much faster, but I'd be afraid of damaging the pads or traces, as others have mentioned. I am a total beginner at component-level hardware repair.
Cutting the pins free from the chip with an abrasive cutoff wheel is actually the safest way to do this.
Tools have been ordered
On a 6300/M24, if the DMA test passes, you should see something other than 43h on the LPT code reader. If it gets stuck at 43h, it didn't pass the DMA channel test. If it displays 43h, then something else, but no 44h, then the DMA channel check passed but the 1st 64K memory test failed. If you see 44h, you're past that entire section.
If it shows 8888 then the board is completely dead. CPU does not start to run BIOS.
You can't test with a random different board, they write their post codes to port 80h and not to parallel port. Only Olivetti and a small other number of brands are using parallel port.
I think this code reader might be defective.
If it helps, this is the exact one I tested with my 6300, using a straight-through LPT cable to hook it up (it doesn't quite fit attached directly to the system): http://www.ebay.com/itm/381724918074?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I used an LPT cable from an old ZIP drive I wasn't using.
<Power switch flipped>
4243
4244
4245
<Onboard dignostic display starts on monitor>
<"All OK" beep> 4648
<Fixed Disk test start> 48A5
<Floppy Disk Drive determined "Not Ready", fixed disk boot> A53F
<End POST>
43
44
45
<"All OK" beep> 48
<Fixed Disk test start> A5
<Floppy Disk Drive determined "Not Ready", fixed disk boot> 3F
<End POST>
