Uses the same type of knurled flathead screw that is all over the back of all kinds of other HP-UX machines at least since the 300 series. The main difference, apart from size, is there is a shoulder on the ones used to fix the rear PCB to the drive "boat", so that even when the screws are tight the PCB can move around slightly to locate itself in the mating connector on the IO PCB.
