He has a model 3 or a 5120, that info seems to only apply to the 5100 or 5110. The model he has has the larger screen and dual 8" floppy drives built in.Hello, there is a lot of technical information for the 5110 at
The Maintenance Information Manual in particular may be helpful.
For the sake of your sale: where are you located? What language or languages does this 5110 have installed? Do you have pictures of it?
Hello Clalat and welcome to the VCFED forum. Please post a quick post about yourself in the "introductions" area and change your avatar to reflect where in the globe you are located. By the way I am also a 5110-3 (5120) owner myself.Hi. I have an ibm 5110-3 + printer 5103 to sell. I have a problem with the monitor of the unit. any suggest to give me ? Or someone have technical diagram of tha unit ? Thanks in advance
In that case you can also add resources from the neigbouring directory at http://bitsavers.org/pdf/ibm/5120/He has a model 3 or a 5120, that info seems to only apply to the 5100 or 5110.
