fdiskitup
where is resistor 1P1 ? is it part of the resistor pack RP1 ? on the resistor pack between pins 5 to 16 are 1ohm resistance.
Yes, part of RP1 - The 'R' was accidentally cut off in my diagram.where is resistor 1P1 ? is it part of the resistor pack RP1 ?
Of course, you are measuring multiple parts in parallel, and so RP1 isn't necessarily at fault. I've encountered resistors in resistor packs go open, but have yet to encounter one go short.on the resistor pack between pins 5 to 16 are 1ohm resistance.
That photo is of the actual one sitting in front of me right now.By the way my card is the early version (green pcb) looks identical to the card here Early mda
Those measurement points are the same as measuring between pins 12 and 14 (Vcc) of U38. My measurement between those two pins is about 4K ohm. As I expected, if I measure between pins 5 and 16 (Vcc) of RP1, I see the same value.on the resistor pack between pins 5 to 16 are 1ohm resistance.
- Faulty PCB
Not to mention the C2's.I thought it was just the 2 sides but some of the "C1" capacitors don't have traces on either visible side.
On U101, I measure 0 ohms between pins 4 and 14.modem7 can you have a look at chip U101 (74ls74) is pin 14 vcc connected to pin 4?
Not far off now.Putting a cut in the trace that runs under the 74LS174 (U39) breaks the short.
