An error message produced by DOS
The power-on self test of the IBM 5150 does not display a count of conventional memory on-screen. Tell us how you determined that the power-on self test is only registering 64 KB.
Multiple possibilities, but as Hak Foo alluded to, incorrect setting of motherboard switch blocks SW1 and SW2 is likely.
See [
here] for the SW1/SW2 settings. Whilst at that web page, note the '
On versus off' section.
The IBM 5150 has a requirement that all four motherboard RAM banks are populated before a RAM card is added. Because of your Tecmar RAM card, I presume that all motherboard RAM banks are populated, and switches 3 and 4 on switch block SW1 are both set to OFF to reflect that population. As for the switch block SW2 setting, per the pointed-to information, the setting will depend on both the BIOS revision fitted to the motherboard, and the total amount of conventional memory fitted in the IBM 5150.
If you need further assistance, the information we would need from you is:
* Which motherboard - the 16KB-64KB one or the 64KB-256KB one ?
* Which motherboard BIOS - see [
here] ?
* Confirmation that all motherboard RAM banks are populated.
* The model of Tecmar card being used.
* What are the switch/jumper settings on the Tecmar card ?
The battery suggests that the Tecmar card is multi-function, the battery probably supporting a real-time clock chip. See [
here].
For an IBM 5150, if SW1 and SW2 are set properly, and the problem was due to a bad connection of the card to an ISA slot, expected is a 201 error at start-up. You did not mention a 201 error.
(RAM wise, the IBM 5150 behaves differently to an IBM 5155/5160.)
No.
