Files in ftp://ftp.software.ibm.com/pc/pccbbs/valuepnt
540to528.exe 171625 12-15-94 64XX 540 H-disk fix for Novell Server
6381fxx.exe 226681 10-29-93 6381 FXX Power Management Disk
6381wg31.zip 9033 05-25-94 Replaces SYSTEM.INI in Win for WrkGroup
atios232.exe 678200 07-26-94 32-bit video driver for OS/2 2.1 on P60/D
atiset01.exe 1061236 07-26-94 ATI/PCI Mach 32 video drivers for OS/2
clock00.exe 35920 06-02-93 Date/Time error fix for OS/2 1.3 on VP
clock01.sys 3686 10-14-93 VP2 OS/2 2.00.1 Date & Time
d2uf4spl.pdf 444257 08-11-98 ValuePoint HMM Supplement April, 1994
dcodeati.exe 893377 01-11-95 OS/2 ATI-TR fix for P60/D
doscdati.exe 21897 01-04-95 Device driver for TR, ATI & Novell P60D
dosdcati.exe 21783 01-11-95 Fix for Video Hangs with Net. Cards and > 16
colors on network
dosports.exe 1792 02-23-94 Initialize COM3 or COM4 on ISA Systems
dossmc.zip 4071 03-24-94 Fix - 6381 or P60/D serial port hangs-DOS
dsaafix.exe 123391 04-02-96 Code fix for IDE 120, 240, 340MB
fastcur.com 19 12-17-94 Fast cursor for 6381
hddpio.exe 6731 05-18-94 Makes 170&245M HD on 6384 P60D a PIO
ibmatid1.exe 950635 01-27-95 ATI Mach32 setup & video drivers 2.3 P60D #1
ibmatid2.exe 1095131 08-16-94 ATI Mach32 setup & video driver 2.3 P60D #2
ibmkbfix.exe 16766 09-15-93 Fix VP keyboard lockup in Windows
ide311.exe 22324 01-02-93 updated disk driver for netware 3.11
idecdfix.sys 12926 12-22-94 IDE CDROM fix for 6387
l6jt68a.exe 428589 06-21-95 Flash BIOS update for ValuePoint 2 v68
l6jt70a.exe 429023 05-06-97 Flash BIOS update diskette VP2 v70
l6jt70a.new 153 06-13-97 Readme for L6JT70A.EXE
l6jt70a.txt 4454 06-13-97 Readme for L6JT70A.EXE
l8jt43a.exe 568599 03-10-95 Flash BIOS update for 6381 v.43
l8jt44a.exe 569232 01-19-96 Flash BIOS update for 6381 v44
l8jt51a.exe 572766 01-05-98 Flash BIOS v51 6381
l8jt52a.exe 569361 01-19-98 Flash BIOS update v52a 6381
l8jt52a.txt 640 01-19-98 Readme for L8JT52A.EXE
ldjt67a.exe 683785 03-01-95 Flash BIOS update 64xx v67
ldjt70a.exe 683887 05-06-95 Flash BIOS update 64xx v70
ldjt80a.exe 631137 01-05-98 Flash BIOS v80A 6472, 6482, 6492, 6484, 6494
ldjt80a.txt 6361 01-05-98 Readme for LDJT80A
ldjt81a.exe 686465 09-10-99 Flash BIOS update diskette v81a 64xx
ldjt81a.txt 6513 09-10-99 Readme file for LDJT81A.EXE
lformat.exe 144660 01-16-95 low-level format utility for 6384 P60/D
ntfloppy.zip 13802 02-15-94 Patch to load Windows NT from diskette
6384-18x, 6384-19x
os2drvp.exe 918273 02-26-93 OS/2 2.00.1 vid recovery dsk - 486 VP1
p60dgs.exe 626719 06-03-94 Diagnostics for P-60D v 4.0
p60nt.exe 147472 03-15-94 Fix for P60D w/527MB hardfile that can't load
WIN NT 3.1
parityfx.exe 768 07-07-93 Fix for Parity Errors on NEW VP's
preinst1.exe 497344 12-29-92 OS/2 Pre-Install Utility Disk (1 of 3)
preinst2.exe 545752 06-23-94 OS/2 - Pre-install utility disk 2 of 3
preinst3.exe 473647 12-30-92 OS/2 Preinstall Utility Disk (3 of 3)
refresh.exe 33756 02-17-95 Refresh Rate Utility for VP Systems
s3-16m.exe 1358907 12-13-94 OS/2 2.1 S3 video drivers
s3132x25.com 6 01-28-94 132 Column mode for S3 Valuepoints.
s3132x43.com 6 01-27-94 132 col mode for S3 VP's
s3cds22.exe 377277 06-15-95 S3 86C805 v2.20 DOS/Utilities
s3cos1.exe 1357586 06-15-95 S3 86C805 OS/2 2.x High Res
s3cwn24.exe 567357 06-15-95 S3 86C805 v2.4B8 Windows
s3dos20.exe 348507 07-23-93 DOS and CAD S3 drivers ver 2.0
s3dos220.exe 388231 12-16-93 S3 DOS and CAD drivers Ver2.2
s61g1423.pdf 1248701 05-18-98 Valuepoint Hardware Maintenance Manual -
September 1993
shadow.exe 6921 05-12-93 Enable/Disable ROM Shadow for NEW VPs
si25dosb.exe 639877 10-13-93 6381 425sx DOS Video Driver Update
si25winb.exe 689013 10-14-93 6381 (Fxx) Windows 3.1 updated SVGA driver
si33dosb.exe 427010 10-13-93 6381 433dx DOS Video Driver Update
si33winb.exe 611643 10-13-93 6381 433dx Windows Video Driver Update
sirq.exe 7759 05-03-94 Fixes for VP Ethernet Cards in 6381 for IRQ's
other than 11
slwdwn.zip 810 02-24-94 Slow down utility for fast CPU's
vp1diags.exe 145208 05-13-93 Diag diskette for orig. 6384 VP1
vp2copro.zip 61010 09-28-94 VP2 Math-coprocessor fix DOS/Win Req/VP2FL65A
vp2diags.exe 181185 01-13-94 PS/VP Diagnostics (Type 2) 1.2 425SX, 433SX,
433DX, 466DX2
vp2fl53a.exe 428380 09-20-94 Flash bios upgrade for ValuePoint 2 v53
vp2fl54a.exe 428442 09-20-94 Flash bios upgrade for ValuePoint 2 v54
vp2fl58a.exe 428382 09-20-94 Flash bios upgrade for ValuePoint 2 v58
vp2fl62a.exe 428425 09-20-94 Flash bios upgrade for ValuePoint 2 v62
vp2fl65a.exe 428441 09-23-94 Flash BIOS update for ValuePoint 2 v65
vp2fl66a.exe 429333 10-26-94 Fix for Danish Language Problem
vp2upmem.exe 156672 04-13-94 Flash For 192K Upper Memory on VP2.
vp386svg.exe 866834 12-22-93 PS/VP 386 SVGA Drivers/Utilities
vp486svg.exe 339833 11-22-94 PS/VP 486 SVGA Drivers/utilities
vpclock.sys 3712 06-29-93 Old clock01.sys for 6384 VP/ OS2 2.00.1
vpp60fl4.exe 721307 09-20-94 Flash Bios update for P60/D;flicker problems
vpp60fl6.exe 722824 09-20-94 Flash Bios update for P60/D v1.00.06
vppdiags.exe 352413 07-07-94 Diagnostics for 64XX ValuePoint
vppfl44a.exe 623043 09-20-94 Flash BIOS upgrade 64XX v44
vppfl53a.exe 428310 09-14-94 Flash BIOS upgrade 64XX v53
vppfl54a.exe 429233 12-22-94 Flash BIOS update 64xx v54
vppfl56a.exe 626543 09-20-94 Flash BIOS upgrade 64XX v56
vppfl58a.exe 627692 09-19-94 Flash BIOS upgrade 64XX v58
vppfl61a.exe 654404 12-10-94 Flash BIOS upgrade 64XX v61
vppfl63a.exe 683707 12-17-94 Flash BIOS update 64xx v63
vppfl64a.exe 684754 12-21-94 Flash BIOS update 64xx v64
vppfl65a.exe 683871 01-20-95 Flash BIOS update 64xx v65
vppnp10.exe 82452 03-08-95 64xx Plug & Play Utility
vpqna.zip 12967 03-13-93 ValuePoint Common Q&A Excellent Info!!
vpsidia2.exe 175302 01-05-94 Diagnostics Diskette for 6381SX/SI VP v1.01
vpsidiag.exe 175302 06-03-94 Diagnostics diskette for 6381 VP v1.01
vpsifl39.exe 569061 09-20-94 Flash BIOS update for 6381 v39
vpsifl40.exe 568677 09-20-94 Flash BIOS update for 6381 v40
vpsifl42.exe 569147 09-20-94 Flash BIOS update for 6381 v42
vpwinbhf.exe 27390 01-12-95 WIN 32 bit disk access for > 527 meg IDE HD
windr386.exe 753476 12-22-92 Windows 3.1 drivers for 386 PS/VP
windr486.exe 1132886 10-19-93 Windows driver for et4000 -vp1
winsmc.zip 6788 03-24-94 Fix - 6381 or P60/D serial port hangs-Windows.
winwgsmc.zip 23162 06-09-94 Fix Problems in Windows for Workgroups 6381,
P60/D
zero_dma.zip 857 05-12-93 3rd party DMA Networking Card Fix
