IBM hotness heck yeah!!!
Kilroy08
I snagged 2 IBM PS/Valuepoint 433SX/Si computers along with a matching monitor, mouse, and 3 model M keyboards.
I saw a socket for a math co processor or upgrade cpu, the 486SX is soldered to the board. Does anyone know which jumper to change when I put in a DX2-66? Plus I'm having a hard time finding the system reference disk. The IBM ftp site no longer has anything for this machine. Machine type is 6381 Model is K50.
I'd like to make it my vintage gaming box.
And for those of you about to ask. Yes, I am using one of the model M keyboards on my modern desktop. C'mon clicky key boards are awesome!!!
IBM PS/ValuePoint files and information
Congratulations on obtaining those ValuePoint systems. Specifications of your system and details of other ValuePoint models are in the Personal System Reference at http://www.lenovo.com/psref/pdf/vpbook.pdf.
IBM's FTP site still hosts the old IBM PC BBS at ftp://ftp.software.ibm.com/pc/pccbbs. Some of the ValuePoint files are in the "valuepnt" folder and elsewhere. Unfortunately, the files are hidden from view, therefore you have to know the file name you're after, but I list the files in the "valuepnt" folder below.
For example, BIOS flash updates for your ValuePoint are there. Jumper settings for your ValuePoint are listed in the ValuePoint Hardware Maintenance Manual located at ftp://ftp.software.ibm.com/pc/pccbbs/valuepnt/s61g1423.pdf; see also the ValuePoint Hardware Maintenance Manual Supplement at ftp://ftp.software.ibm.com/pc/pccbbs/valuepnt/d2uf4spl.pdf.
There is lots of historical information on 1990s IBM PCs in the IBM PC Partner Information hosted at http://ps-2.kev009.com:8081/pcpartnerinfo/ctstips and the IBM Electronic Pocket Reference Manual at http://ps-2.kev009.com:8081/eprmhtml. Use a search engine to search for content inside kev009.com.
Files in ftp://ftp.software.ibm.com/pc/pccbbs/valuepnt
540to528.exe   171625 12-15-94  64XX 540 H-disk fix for Novell Server
6381fxx.exe    226681 10-29-93  6381 FXX Power Management Disk
6381wg31.zip     9033 05-25-94  Replaces SYSTEM.INI in Win for WrkGroup
atios232.exe   678200 07-26-94  32-bit video driver for OS/2 2.1 on P60/D
atiset01.exe  1061236 07-26-94  ATI/PCI Mach 32 video drivers for OS/2
clock00.exe     35920 06-02-93  Date/Time error fix for OS/2 1.3 on VP
clock01.sys      3686 10-14-93  VP2 OS/2 2.00.1 Date & Time
d2uf4spl.pdf   444257 08-11-98  ValuePoint HMM Supplement April, 1994
dcodeati.exe   893377 01-11-95  OS/2 ATI-TR fix for P60/D
doscdati.exe    21897 01-04-95  Device driver for TR, ATI & Novell P60D
dosdcati.exe    21783 01-11-95  Fix for Video Hangs with Net. Cards and > 16
                                colors on network
dosports.exe     1792 02-23-94  Initialize COM3 or COM4 on ISA Systems
dossmc.zip       4071 03-24-94  Fix - 6381 or P60/D serial port hangs-DOS
dsaafix.exe    123391 04-02-96  Code fix for IDE 120, 240, 340MB
fastcur.com        19 12-17-94  Fast cursor for 6381
hddpio.exe       6731 05-18-94  Makes 170&245M HD on 6384 P60D a PIO
ibmatid1.exe   950635 01-27-95  ATI Mach32 setup & video drivers 2.3 P60D #1
ibmatid2.exe  1095131 08-16-94  ATI Mach32 setup & video driver 2.3 P60D #2
ibmkbfix.exe    16766 09-15-93  Fix VP keyboard lockup in Windows
ide311.exe      22324 01-02-93  updated disk driver for netware 3.11
idecdfix.sys    12926 12-22-94  IDE CDROM fix for 6387
l6jt68a.exe    428589 06-21-95  Flash BIOS update for ValuePoint 2 v68
l6jt70a.exe    429023 05-06-97  Flash BIOS update diskette VP2 v70
l6jt70a.new       153 06-13-97  Readme for L6JT70A.EXE
l6jt70a.txt      4454 06-13-97  Readme for L6JT70A.EXE
l8jt43a.exe    568599 03-10-95  Flash BIOS update for 6381 v.43
l8jt44a.exe    569232 01-19-96  Flash BIOS update for 6381 v44
l8jt51a.exe    572766 01-05-98  Flash BIOS v51 6381
l8jt52a.exe    569361 01-19-98  Flash BIOS update v52a 6381
l8jt52a.txt       640 01-19-98  Readme for L8JT52A.EXE
ldjt67a.exe    683785 03-01-95  Flash BIOS update 64xx v67
ldjt70a.exe    683887 05-06-95  Flash BIOS update 64xx v70
ldjt80a.exe    631137 01-05-98  Flash BIOS v80A 6472, 6482, 6492, 6484, 6494
ldjt80a.txt      6361 01-05-98  Readme for LDJT80A
ldjt81a.exe    686465 09-10-99  Flash BIOS update diskette v81a 64xx
ldjt81a.txt      6513 09-10-99  Readme file for LDJT81A.EXE
lformat.exe    144660 01-16-95  low-level format utility for 6384 P60/D
ntfloppy.zip    13802 02-15-94  Patch to load Windows NT from diskette
                                6384-18x, 6384-19x
os2drvp.exe    918273 02-26-93  OS/2 2.00.1 vid recovery dsk - 486 VP1
p60dgs.exe     626719 06-03-94  Diagnostics for P-60D v 4.0
p60nt.exe      147472 03-15-94  Fix for P60D w/527MB hardfile that can't load
                                WIN NT 3.1
parityfx.exe      768 07-07-93  Fix for Parity Errors on NEW VP's
preinst1.exe   497344 12-29-92  OS/2 Pre-Install Utility Disk (1 of 3)
preinst2.exe   545752 06-23-94  OS/2 - Pre-install utility disk 2 of 3
preinst3.exe   473647 12-30-92  OS/2 Preinstall Utility Disk (3 of 3)
refresh.exe     33756 02-17-95  Refresh Rate Utility for VP Systems
s3-16m.exe    1358907 12-13-94  OS/2 2.1 S3 video drivers
s3132x25.com        6 01-28-94  132 Column mode for S3 Valuepoints.
s3132x43.com        6 01-27-94  132 col mode for S3 VP's
s3cds22.exe    377277 06-15-95  S3 86C805 v2.20 DOS/Utilities
s3cos1.exe    1357586 06-15-95  S3 86C805 OS/2 2.x High Res
s3cwn24.exe    567357 06-15-95  S3 86C805 v2.4B8 Windows
s3dos20.exe    348507 07-23-93  DOS and CAD S3 drivers ver 2.0
s3dos220.exe   388231 12-16-93  S3 DOS and CAD drivers Ver2.2
s61g1423.pdf  1248701 05-18-98  Valuepoint Hardware Maintenance Manual -
                                September 1993
shadow.exe       6921 05-12-93  Enable/Disable ROM Shadow for NEW VPs
si25dosb.exe   639877 10-13-93  6381 425sx DOS Video Driver Update
si25winb.exe   689013 10-14-93  6381 (Fxx) Windows 3.1 updated SVGA driver
si33dosb.exe   427010 10-13-93  6381 433dx DOS Video Driver Update
si33winb.exe   611643 10-13-93  6381 433dx Windows Video Driver Update
sirq.exe         7759 05-03-94  Fixes for VP Ethernet Cards in 6381 for IRQ's
                                other than 11
slwdwn.zip        810 02-24-94  Slow down utility for fast CPU's
vp1diags.exe   145208 05-13-93  Diag diskette for orig. 6384 VP1
vp2copro.zip    61010 09-28-94  VP2 Math-coprocessor fix DOS/Win Req/VP2FL65A
vp2diags.exe   181185 01-13-94  PS/VP Diagnostics (Type 2) 1.2 425SX, 433SX,
                                433DX, 466DX2
vp2fl53a.exe   428380 09-20-94  Flash bios upgrade for ValuePoint 2 v53
vp2fl54a.exe   428442 09-20-94  Flash bios upgrade for ValuePoint 2 v54
vp2fl58a.exe   428382 09-20-94  Flash bios upgrade for ValuePoint 2 v58
vp2fl62a.exe   428425 09-20-94  Flash bios upgrade for ValuePoint 2 v62
vp2fl65a.exe   428441 09-23-94  Flash BIOS update for ValuePoint 2 v65
vp2fl66a.exe   429333 10-26-94  Fix for Danish Language Problem
vp2upmem.exe   156672 04-13-94  Flash For 192K Upper Memory on VP2.
vp386svg.exe   866834 12-22-93  PS/VP 386 SVGA Drivers/Utilities
vp486svg.exe   339833 11-22-94  PS/VP 486 SVGA Drivers/utilities
vpclock.sys      3712 06-29-93  Old clock01.sys for 6384 VP/ OS2 2.00.1
vpp60fl4.exe   721307 09-20-94  Flash Bios update for P60/D;flicker problems
vpp60fl6.exe   722824 09-20-94  Flash Bios update for P60/D v1.00.06
vppdiags.exe   352413 07-07-94  Diagnostics for 64XX ValuePoint
vppfl44a.exe   623043 09-20-94  Flash BIOS upgrade 64XX v44
vppfl53a.exe   428310 09-14-94  Flash BIOS upgrade 64XX v53
vppfl54a.exe   429233 12-22-94  Flash BIOS update 64xx v54
vppfl56a.exe   626543 09-20-94  Flash BIOS upgrade 64XX v56
vppfl58a.exe   627692 09-19-94  Flash BIOS upgrade 64XX v58
vppfl61a.exe   654404 12-10-94  Flash BIOS upgrade 64XX v61
vppfl63a.exe   683707 12-17-94  Flash BIOS update 64xx v63
vppfl64a.exe   684754 12-21-94  Flash BIOS update 64xx v64
vppfl65a.exe   683871 01-20-95  Flash BIOS update 64xx v65
vppnp10.exe     82452 03-08-95  64xx Plug & Play Utility
vpqna.zip       12967 03-13-93  ValuePoint Common Q&A Excellent Info!!
vpsidia2.exe   175302 01-05-94  Diagnostics Diskette for 6381SX/SI VP v1.01
vpsidiag.exe   175302 06-03-94  Diagnostics diskette for 6381 VP v1.01
vpsifl39.exe   569061 09-20-94  Flash BIOS update for 6381 v39
vpsifl40.exe   568677 09-20-94  Flash BIOS update for 6381 v40
vpsifl42.exe   569147 09-20-94  Flash BIOS update for 6381 v42
vpwinbhf.exe    27390 01-12-95  WIN 32 bit disk access for > 527 meg IDE HD
windr386.exe   753476 12-22-92  Windows 3.1 drivers for 386 PS/VP
windr486.exe  1132886 10-19-93  Windows driver for et4000 -vp1
winsmc.zip       6788 03-24-94  Fix - 6381 or P60/D serial port hangs-Windows.
winwgsmc.zip    23162 06-09-94  Fix Problems in Windows for Workgroups 6381,
                                P60/D
zero_dma.zip      857 05-12-93  3rd party DMA Networking Card Fix
Looking for ibm 6381 vp-si 486DX2-66MHz
Looking for ibm 6381 vp-si 486DX2-66MHz. Is yours working? Will u sell? I have one no longer working it ran cash register system in my restaurant.
