hunterjwizzard
- Joined
- Mar 20, 2020
- Messages
- 2,808
Hey folks.
I've just finished a rather inexpert execution of an bolt mod on my IBM model M. I finally got it reassembled today and working 99%, but the + sign on the num pad is a problem. Its squishy and it sticks. I pretty much have to keep a tool handy do pry it back up because it won't come on its own.
What I have tried so far:
-swapped the num pad + & Enter key, problem stays with the slot
-pulled the 9 off from the num pad and put it in the barrel with the spring, works perfectly
-first removed the washer from the bolt underneath the key
-removed the whole damn bolt
-checked the support over and over again, everything looks clear.
But no matter how many times I take it off and re-seat it, its still mushy and sticks.
Some background on the bolt mod: the barrel plate cracked in a few places on the final re-assembly, but not anywhere near the num pad. The ; and ' keys had problems which were resolved by removing the bolt from in between them. The front of the keyboard is still "smiling" just a bit. I ended up having to omit the first row of bolts to make it fit properly, but the catch should be holding that part of the board together. I've been typing on it all day and besides that num pad + sign problem everything else appears to be working correctly.
Any ideas?
Any ideas?
