Well I opened the power-supply didn't see anything missing or loose, put it back together and powered it on... And it worked...
So I put it all back together other then its lid and tried turning it on... And nothing... I hit the power-supply and it turned right on...
I'm thinking it has a loose solder joint somewhere... I'll have to take its board out too and check the bottom side. Anyway so I got it running and that's after I cleaned all the connections I could and I ran the reference disk again since I had the battery and speaker disconnected and when I ran a self test again it said '1 ESDI Drives' instead of the '0 ESDI Drives' I was getting before. I was thinking 'no way this is going to just work now'...
Well it did passed all its tests and I restarted it and it booted to Windows for Workgroups 3.11! So everything seems good now!
Other then that power supply of-course.
