MattisLind
Yes. That is identical to what mine did. I successfully used a GOTEK with FlashFloppy firmware.
I learnt a bit about the VRM Maintenance Facility from the IBM RT PC Problem Determination Guide. It can be started from VRM floppy 1.
In there it was possible to list the contents of the filesystems on the disk.
Indeed this machine has been used for CAD work. There is directories named CATIA in there.
hd0 is definetely the root filesystem, but I cannot figure out why it refuses to boot from the disk or why it refuses to IPL hd0 using the VRM Maintenance Facility.
