smplfyi
Can anybody locate me the redbook and the schematic for the motherboard.
I am trying to repair my 7249-851 and cannot find either !
| VCF SoCal | Feb TBD, 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | Jun 25 - 27, 2027, | Westin Dallas Fort Worth Airport |
| VCF Southeast | Aug TBD, 2027, | Atlanta, GA |
| VCF West | Aug TBD, 2027, | Mountain View, CA |
BuMP
Token Ring is a complete YES as I found the card with A token Ring card and my assumption is YES too for ethernet.
I tried a copy of OS/2 for Power PC and it seems it's more designed for the desktop RS/6000 systems and not the 850.
In the meantime, I have managed to wrangle back the hard drive so it's installed again and I raided RE-PC Seattle for a floppy drive and walked out with a 2.88mb drive for $3.
I still however can't find the restore CD's for the system so for a lot of the time it's been sitting as a paperweight...
I wish I knew someone who I could borrow their discs.
I have the maintanance manual which I have scanned if you would like a copy 30H2383 also the user manual 79H3648 and the safety booklet 45H3699
I have not yet scanned these but if there is call for them the winter is coming so I may have time
MikeS
The bottom cover removed. A square cutout is made in the board under the CPU to connect the ceramic substrate to the metallic cover for heat-spreading.
The CPU board with its two connectors. 33.33MHz frequency from oscillator is tripled for 100MHz system clock. A metallic bar connects to the top of the CPU to transfer heat away.
Here's what everyone wants to see!
The PowerPC 603e CPU @ 100Mhz. It comes in a flip chip QFP208 package potted with a blue compound. This package was used for the PowerPC 601, on some early IBM versions of the PowerPC 604, but rarely on the 603e which also came in a full ceramic QFP208 package.
:arrow: Disassembling the display does not require to take the frame out of the unit. 6 screws covered by adhesive pads holds the cover. The two upper screws are made of white plastic.
The LCD is an active matrix 800x600 24bit color module (PN 84G6835). Very interestingly, the inverter and CCFL lamp (PN 85G0531 - FRU 85G1031) are mounted on a removable plastic frame meant to be replaced in case of failure. It is the very first time I see a LCD made to be serviced without taking everything apart.
My unit also came with a PCMCIA ethernet card, without the dongle. I am wondering if this is a regular unit or one specifically designed for RS/6000 systems.
Now will be the time to do more troubleshooting in order to repair the backlight, since I doubt the display assembly was used in another IBM laptop. The replaceable CCFL seems to be specifically designed for the ThinkPad 850.
Great teardown, thanks a lot for doing this. I have dumped the firmware bios revisions for the 850/851 Thinkpads, the chip under the label is a 29F040A from Fujitsu. Both bios versions can be found here: https://github.com/ArcadeHacker/Dumps/tree/main/Computers/IBM/Laptops/IBM ThinkPad 850
Revision 40H5218 is dated 08 12 1996
Revision 91G0610 is dated 07 03 1995
At some point I will also try to dump the HD6473388 MCU code.
Regards.
This reinforces my worry that most of the SCSI emulators out there are slow, expensive, inefficient and will ruin your day if you don't configure it correctly.I'm starting to think that the bad SCSI2SD blew the fuse and took the SCSI controller with it.
I'm sorry your experiences have been poor. I own ten ZuluSCSI devices (of various sizes and models) and they are in regular use on both DEC and Apple systems. I find them somewhat faster than the spinning platter drives they replaced, reasonably priced (particularly the Zulu Pico Slim if you solder it together yourself) and cannot theorize how one could possibly damage the host system.This reinforces my worry that most of the SCSI emulators out there are slow, expensive, inefficient and will ruin your day if you don't configure it correctly.
