I few weeks ago I was tinkering on a 5160 that would only count to 64K even though it had 256K onboard + 256K on a card. I have a cheap thermal camera so I took a peek and... viola, it stood out like a sore thumb. I swapped the chip and it went to 256k like champ. (see attached pic, center'ish)
The same trick didn't work on the memory expansion card though. I was able to see different blocks of memory were at different temperatures though and upon closer inspection they were different brands. I was able to determine which was the first bank on the card and based on the on-screen error determined it was the parity bit. I swapped the first and last chips and sure enough the error moved, so I replaced the offending chip and bingo... 512K.
I later tested the two chips (outside of a computer, so maybe not a great test) and the one from the mainboard failed, while the one from the expansion card passed... then they both went into the trash bin.
