RSX11M+
- Joined
- Feb 14, 2011
- Messages
- 1,075
I can well understand there might be confusion surrounding the KM11 modules and their use. (now that I compare the docs to the actual thing)
For those not familiar, these links may be instructive:
Images from those links:
Original:
DIY Alternative Approach:
Another DIY:
With these in mind... I'd like to get some more details of your thoughts...
Observations:
Your design uses numeric displays where individual LEDs were - for bus address bits. There are 9 bits of bus so values can range from 777 to 000. However, meaning of these is dependent on other states - you will need to interpret. (I'm sure you've considered this - I'm just catching up)
The original docs for the KM11 show "overlay cards" to assist in this interpretation. You'll need to translate as needed.
Since there has been some confusion about your display decoder's connections, I'd advise that you power your module out of the system and manually manipulate card fingers to prove bus connections will be displayed correctly before you proceed "in chassis".
- Good Overview of the original modules
- One version of a substitute and it in use
- Another substitute and the creator's basis documents
Original:
Another DIY:
- The original KM11 has "NAND-Latches" using a 74LS00... how did you accomplish this function on yours?
- The original also has a transistor, connected open-collector to BUS SSYN L - how did you handle this?
Observations:
