Chicco Chacco
- Joined
- Aug 27, 2021
- Messages
- 18
Intel Professional Workstation - Unknown OnBoard Ethernet/LAN-Controller&Motherboard
Hello to all in this Forum.
I'm new in this forum and I hope that someone can help for my special wish.
The reason is: I've taken my Intel-based Professional Workstation - [Panther] - year 1992 ( ? with a LP486E motherboard ? ) from the attic.
I'm sure, it is the same as in the Youtube videos - "An Intel Branded EISA-Based 486 Desktop Computer? (Part 1 to Part 3 - e.g. https://www.youtube.com/watch?v=fK7QMAX0BmQ)".
Because this PC was not used about 20 years the Dallas DS1287 RTC chip was empty. So, all BIOS-/LAN- and EISA-settings were lost.
I've replaced the DS1287 now by a DS12887 and I also replaced the original hard drive (she was unfunctional) with a CONNER CFS-210A 210MB 3.5 SL IDE AT with an already installed Windows95 OSR2.
In the Phoenix SETUP Utility (Version 1.00.xx S0D) [ = nearly the same as the BIOS in YouTube video] I entered the corresponding hard drive CHS parameters and the workstation starts without any problems and Windows 95 is loaded.
This workstation-model has no CDROM-Drive, no USB nor other installed cards beside two unused EISA-Slots.
Beside the hard disk, she has a floppy drive and in addition to their standard connections, an "on board LAN-Controller".
I do'nt know the specifications for this LAN/Ethernet-Controller. Is it 3com or Intel or Novell or Realtek or something other? I don't know but it's necessary to make the LAN-Controller known in the system and then establish a network connection to the Internet via LAN.
The problem is, that I don't know the specs which mainboard, which LAN-Controller is installed in the PC and which settings in the system control panels or in the EISA Configuration Utility are necessary!
So I used a EISA Configuration Utility 2.0 (downloaded from the URL https://archive.org/details/remaker_gmail_CF) to enable onboard LAN-Controller and also in the BIOS I enabled onboard LAN-Controller.
Then I tried the network option for INTEL here "82595-based-Ethernet" (which is one of many others, such as 3com, Novell, Realtek etc.) and some others, but after the restarts the PC hangs with the Windows 95 screen or loops or displays errors.
Therefore I would like to ask all, if someone in this forum could help, how to set up an Internet connection via Ethernet/LAN.
Note:
I have neither floppy disks for an "EISA Configuration Utility (ECU)" nor for Windows 95.
As ECU, I downloaded the “LP486E Drivers DOS OS / 2 Windows” from the URL https://archive.org/details/remaker_gmail_CF and installed this ECU on the workstation.
Has someone of you a workstation like my?
What could be the brand of my motherboard and which onboard LAN Controller could it be?
My System shows as network-option for INTEL e.g. "82595-based-Ethernet" which is one of many others (e.g. 3com, Novell, Realtek,etc.).
What's needed for LAN activation & connection to Internet and wich settings and steps are to do?
Has anybody used a harddisk greater than 504MB (e.g. 160GB) with such a workstation?
Kindly regards
Robert (not the youngest)
P.S.
A picture of this PC can also be seen at
https://www.computerhistory.org/collections/catalog/102677995.
Note:
Kindly regards
P.S.
