glitch
I've been going through more Sun stuff lately, and decided to get IRC up and going on a few things. First off, SPARCstation 10, Ross HyperSPARC 166 MHz, 128 MB RAM, OpenBSD 5.9, running EPIC4 (excuse the mess!):
EPIC4 was compiled from source *on* the SS10. Total configure and build time around 25 minutes! Console terminal is a DEC VT320 in 132 column mode. Took a bit to figure out that, when using a 132-column terminal as the system console, you have to set the width in NVRAM. Setting TERM=vt320-w is not sufficient.
Second, a SPARCstation IPX, 40 MHz CPU, 32 MB RAM, SunOS 4.1.4, running ircII-2.2.9:
Works fine in a SunView console, too!
ircII was also compiled on the actual machine, I forgot to time it, but total build time was around 20 minutes or so. It's restricted to 8-char nicks. It's the oldest version I could find that would just build on SunOS 4 -- ircII-1.75 failed to build.
