IBMMuseum
- Joined
- Aug 28, 2006
- Messages
- 1,515
...FWIW, my own internal net uses 10.0.0.x addresses. That way, I know I'm not conflicting with any of the various boxes on the wire.
VisionNet DSL modem? Mine is a Class A as well. Just lock down your subnet tighter if you have to do a VPN.
...The other way to avoid that is to make a list and your own plan. I tend to avoid DHCP because I haven't got an easy way to know what IP gets picked without physically accessing the machine in question.* Perhaps that's just my ignorance, but I avoid it by using static. That said DHCP is handy for testing and guests. So I reserve 10 addresses for that...
Get a device that allows its DHCP Server functionality to set reserved IP addresses (based on the MAC address). As I identify a new device, I put it in the range for that user (transitional devices from guests have their own area), and only a certain block (mine) can administer the managed network equipment. Yeah, I put quite a bit planning into it.
...Setting up a name server for anything under 100 computers is overkill in my opinion...
Depends on how easy it is to set up, my NAS has that functionality anyway...
With all of the above, I can pick up my laptop to go between work and home, without changing anything...
