siliboi
I’m curious if these are rare I haven’t seen any on eBay yet what do they do?
| VCF East | Apr 17 - 19, 2026, | InfoAge, Wall, NJ |
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
I’m. Not 100% sure yet I put an offer in on some machines it looks like it says accelerator 16You're going to have to be more specific. Radius made all sorts of accelerator boards. If you don't have an exact model number, take a picture of it. Any sort of compact Mac accelerator these days are rare, but more and more of them have been cloned and have gerber files available for them to be produced again.
If it has a CPU like a 68020/030 on it, it's a CPU accelerator. If it has a video port on the back of the machine, it's for an external display.
Any sort of CPU accelerator is highly beneficial on a compact Mac, because of their slow 8 MHz 68000s. They usually can't do anything about the maximum memory, but having a faster CPU makes them much more usable. I have a 25 MHz 68030+68881 TotalSystems Gemini Ultra in my Mac SE. It's one of the few accelerators that has additional memory on it, so it doesn't have to rely on the slow 16 bit wide memory on the main logic board.
@GiGaBiTe It seems a bit silly to call the stock hardware configuration for the time "slow" simply because you have faster options now.
That said, do you think that the CPU speed is the bigger factor or is the "problem" the 16-bit external data bus and memory used?
FYI as well, when the SE launched in March 87, you had System 4. System 6 was still a year away and system 7 was four years away. 4mb of ram, while still limiting (a reminder the mac II shipped at the same time as the SE and why would you undermine your next generation machine like that??) was still gobs of ram for running a lot of applications. (EG: Microsoft Excel and Aldus Pagemaker, both of which also being applications that would take advantage of a 68020 accelerator) There is lots of proof that mid-80's compact macs continued to have a relatively good chunk of the low-end market even by the time System 7 came out. (EG: Robyn Miller used one for music composition during the development of Myst even though they had the budget for newer and faster macs)The 4 MB RAM ceiling would prove to be a serious limitation of the hardware as memory demands exploded in the late 80s and early 90s with System 7. Apple could have had up to 16 MB on the 68000, but to maintain backwards compatibility with software, they had to keep system devices peppered all over the 68000 address space.
No I called them slow because in primary I remembered we had mac se shaped computers that were colour and we all hated them and ran for the pcs in the computer lab because they took like 12 minutes to boot and we had 30 mins in the lab so time was half gone for games when you literally got it started@GiGaBiTe It seems a bit silly to call the stock hardware configuration for the time "slow" simply because you have faster options now.
Once I get the radius system working I’ll let ya know it’s reporting error 000000003 000000000fI was cracking open some Macs for #Marchintosh, doing some regular checks on caps and functionality and had this out. It's a Novy ImagePro 25 with a 68030 25Mhz CPU on a Mac SE with added memory. There were a bunch of accelerators for the SE. This particular one had a 50 Mhz option as well. I'll be honest, sometimes sellers don't even mention accelerator cards so they could be out there but hidden. I did not spend any extra for the SE with an accelerator. Your mileage will vary, of course.
That one should be pretty powerful for sureI was cracking open some Macs for #Marchintosh, doing some regular checks on caps and functionality and had this out. It's a Novy ImagePro 25 with a 68030 25Mhz CPU on a Mac SE with added memory. There were a bunch of accelerators for the SE. This particular one had a 50 Mhz option as well. I'll be honest, sometimes sellers don't even mention accelerator cards so they could be out there but hidden. I did not spend any extra for the SE with an accelerator. Your mileage will vary, of course.
I think I have a smart port I have a boatload of disc and Internet drives floppy enclosures haven’t even been through a 1/4 of it all yetNice straw man argument there. Nobody said anything about comparing the Mac SE to modern anything.
The Mac SE was slow when it was released in 1987, and even slower for the FDHD spec in 1989. The machine had the same ~7.8 MHz 68000 that the original 1984 model did and had largely similar performance due to the CPU having to manage everything in software. The only difference was the higher RAM ceiling of 4 MB, SCSI, ADB and 1.44M floppies in the FDHD spec. The 4 MB RAM ceiling would prove to be a serious limitation of the hardware as memory demands exploded in the late 80s and early 90s with System 7. Apple could have had up to 16 MB on the 68000, but to maintain backwards compatibility with software, they had to keep system devices peppered all over the 68000 address space. Some accelerators like the TotalSystems Gemini can use the 68030 MMU to remap those devices to other locations and allow a larger chunk of memory to be used.
In mid 1989, you could get a complete 386 system at 20 MHz with a color VGA monitor and a hard drive for a largely similar cost to the FDHD, or cheaper than the FDHD with a monochrome monitor. https://archive.org/details/PC-Mag-1989-08-01/page/n1/mode/2up?q=tandon+386
The SE FDHD with a 20 MB hard drive was $3,700. https://lowendmac.com/1987/mac-se/
Apple kept the 68000 in use for *far* too long. This wasn't even their last 68000 machine, they simplified the SE further into the Classic in 1990 and kept it into production until 1992. They had fallen into the same trap as the Apple II with backwards compatibility. In the Apple II case, keeping the CPU at 1 MHz until some of the final machines like the IIc+ at 4 MHz and IIgs with the 65816 at 2.8 MHz.
The CPU speed is the biggest problem, because the SE is entirely software driven via the OS and Toolbox ROM. The frame buffer and floppy access use an enormous amount of processing time and leave little to applications to use. The 16 bit data bus isn't really a problem because the system isn't fast enough as it is to fully saturate it. It only becomes an issue when you start adding accelerators, which is why the more advanced ones had their own RAM slots to have 32 bit memory access.
By the late 1980s, the 68000 was available in speeds of 16 MHz, which could have been used to drastically improve the speed of the machine. The Brainstorm SE accelerator of the mid 90s showed just how fast a SE could go with a fast 68000 and a reworked ASIC, it was nearly as fast as an LC II with a 68030. https://tinkerdifferent.com/attachm...rm-accelerator-for-the-macintosh-se-pdf.4139/
Or they could have done like the IIc with the Smart Port 800k disk drive and had a 6502 offload the disk routines from the 68000. The 6502 by then was a cheap jellybean part that was sold by the millions. One of the Mac II machines did this to speed up floppy disk access. Because even on a 68020/030, bit banging the floppy drive takes up a ton of CPU time.
Once o get it fully running I’ll do that comparison test I always see on YouTube apparently some of the accelerator cards and roms can really speed it upGiven how limited the number of accelerators were for the SE, I'm going to assume the only thing Radius had was the Radius SE Accelerator. - https://wiki.preterhuman.net/Radius_SE_Accelerator
I've seen exactly one and it was nearly 15 years ago at The Hackery and I never got the chance to actually see how much better it was compared to a normal SE. I have no recent experience with it but the internet seems to imply that unless you have a ROM upgrade (the dumps of which do not appear to be online...) you are stuck with System 6 which IMO for a 68020 is fine but in this day and age unless one falls into your lap it's probably better to save the PDS slot for ethernet or the PC 5.25" card.
