Is the mac se radius accelerator rare machine
One side of the rails usually has notches in it so you can slide the board back just a bit and hinge it out. I can get my SE FDHD board out with the TotalSystems Gemini Ultra mounted to it out that way and I don't have to bend the case.
There’s a black connector that connects to a riser card which goes past the crt , this connector only lets me slide the motherboard halfway to the notches before stopping it on the metal case so I can’t even get to the notches to hinge it’s screwed into the mobo from the top and there’s no way to get at the screws so far I don’t see a way to avoid bending
Some upgrades require you to use leverage to remove the board as the upgrade itself will prevent it from being removed the normal way. Slide it as far as it will go to make sure the front edge of the board is clear of the chassis. Next, insert a spudger or (if you're careful) a flathead screwdriver in the gap between the board and chassis rail. Apply gentle outward pressure so you flex the chassis rail outward while pushing the motherboard upward and out of the chassis.
The chassis rail only has to move outward about a millimeter, and it'll spring back to its original position once you get the board out.
Do the same to get the board back in. Place one edge of the board all the way into one rail, then place the spudger between the board and other rail. Gently pull your spudger inward to flex the rail outward and move the motherboard downward back in place. Just make sure the front edge of the board is clear of the lip of the chassis before doing so.
I did it so many times at one point that I was able to do it by hand. The chassis rail really doesn't need to move outward that much.
Oh boy lol 😆 I appreciate the advice we’ll get her out without breaking anything I’ve got a few spudgers
