Hi there,
So I've been having an issue. I have a 486 build that I'm trying to put together but I can't find a case that fits. It's a regular AT motherboard and all regular cards, but the motherboard always seem to end up sitting too low in the case. It's the bracket on the ISA cards that make solid contact with the backplate BEFORE the ISA cards themselves are properly socketed in the ISA slots.
I've tried two different cases now and I have the same problem in both. I've tried both cases wth a 386 motherboard and while the ISA cards are not ALL the way in, the make comfortable contact. The standoffs are 5mm or thereabouts. Regular PC motherboard standoff height. One case came with AT plastic standoffs but they were the same height.
Has anyone else had this problem, and are there any known, good solutions? I have been looking around for taller standoffs, a couple of mm would probably make a build possible, but I can't find those floating AT standoffs in any other height then the regular 5mm'ish so I would need replacement, which would meem having standoffs with enough "screwside-length" to use a bolt on the backside.. It's been a frustrating couple of months trying to put this thing together and I've just had a bit of a soul-killing experience so I thought I'd ask here if anyone has any suggestions.
