Issues booting a laptop - general laptops, not just GRiD
Caleb H
Colorado, USA
So I've got this weird issue with a GRiD 1660 equivalent; when I got it for repair, it wouldn't boot at all, and after I replaced all the capacitors, it will boot once, but if the internal battery and capacitors have any charge, it will fail to boot again. It gets stuck in a sort of semi-on state where it thinks its on, so it refuses to turn on. I have a video of what it's doing:
And I have the service manual with a full schematic:
Anyone have any idea where to start looking? I've stared at the capacitors, and they all look like the right value and soldered correctly, but I'd still guess that the cause of this issue might be either something I did while replacing the caps, or something that happened after the internal battery leaked on the lower main board, which I cleaned off with vinegar as best I could, but there could be some damage to something in the area.
Maybe it has something to do with the soft-power circuitry or initializing the video controller?
The video footage makes it look like pressing the power button when it's on puts the system into a kind of 'sleep mode' which it then fails to wake up from without a hard reset/power cycling.
My guess was the soft power circuitry, but I'm not sure where exactly it is. For the video controller, wouldn't the fact that I can unplug it and then plug it back in, and the power light immediately turns on, suggest that it's having trouble turning off, not trouble turning on? I don't have a battery but I think it's reasonable to guess that if it had one, then the power light would never turn off. Maybe I could track down what turns the power light on and go backwards from there.
Completely cutting the power, which is what likely happens if you unplug this unit and it has no battery attached, should effectively result in losing the contents of memory and the processor registers/state.
So when you plug it back and press the power button you would expect a cold boot.
Part of the difficulty here is knowing how the soft power circuitry works.
My assumption (last post) is that pressing the power button while the system is on results in a sleep/suspend if there is power available (AC only, Battery only, or AC+Battery).
If that's true, you would expect to be able to wake it back up with the power button or keyboard activity.
Maybe that doesn't function properly without a battery installed? In which case it might not be able to wake itself up because the memory contents have been lost. And it wouldn't necessarily reinitialize the hardware.
In that "stuck" state does holding the power button down for 5-10 seconds result in a complete power down?
