OK, thanks for the explanation!Again, thanks for testing. I just want to mention this;
This setting is drive dependant and should work regardless of controller used. You should not disable Block Mode Transfers unless you experience problems with it (i.e. the drive you are using is not compatible with it). If you ever change the drive to something that actually supports it (a real harddrive, for example) you will lose quite a bit of performance, unless you also reflash the settings of XUB. It won't hurt having it enabled for CF cards, even if most CF cards do not support more than 1 block per transfer.
