See the 1701 entry at [here], in particular, the link within the description of 1701.
BTW. Your hard disk controller is an 'IBM Fixed Disk Adapter'.
You are referring to Cassette BASIC. It is is ROM.
I too have an 'IBM Fixed Disk Adapter' in my IBM 5160. I disconnected the data cable from it. After that, the IBM Fixed Disk Adapter did not display a 1701 error at power-on time. That is because the power-on diagnostics (POD) code (i.e. executed at power-on time) within the BIOS ROM of the IBM Fixed Disk Adapter does not do anything that reads the disk surface.On my way to work this morning I realized I didnt hook up the DATA cable. SMH!
Ill hook that up when I get home .
Does the RAYXTMFM.EXE tool at [here] report a problem?
If the HDD controller is indeed defective, then there's little that you can do with any (typical) hard drive until you get it repaired/replaced.
I could be mistaken, but from the above photo, you appear to be driving output to an LCD monitor. You'll likely never get anything close to what you should see unless you use something that can handle true CGA from your (assumed working) CGA card or replace it with something that can drive the monitor properly.
I don't have anything eles to try at the moment. Plain text is fine in 80 column mode. 40 column its jumping up and down.
Are you using the RCA composite output or the 9 pin TTL output on your card?
Regarding RAYXTMFM's inability to identify your 5160's motherboard BIOS ROM's. Are you able to provide a photo of those ROM's (U18 and U19) ? I am curious.So I tried the RAYXTMFM and received this....
BIOS unable to identify, and no BIOS expansion ROM.
Regarding RAYXTMFM indicating no BIOS expansion ROM at C8000, the BIOS ROM on your IBM Fixed Disk Adapter. The motherboard was able to 'see' the ROM before - it is what generates the 1701 error. To attach the data cable, you probably needed to remove the IBM Fixed Disk Adapter from its ISA slot. Verify that your IBM Fixed Disk Adapter is now properly sitting in its ISA slot.
The "1501512" on U18 confirms a revision of 11/08/82. I guess that the contents of your 1501512 differs slightly to my 1501512. I will do further research on that.Ok. Here it is
RAYXTMFM's failure to identify your motherboard BIOS does not impact on part 3 ("ID the BIOS ROM at C8000").
So verify that your IBM Fixed Disk Adapter is properly sitting in its ISA slot.
(And if the motherboard is out of the computer, do not have the IBM Fixed Disk Adapter in slot #8 - slot #8 is 'special'.)
Obviously, your computer should not be showing instability like that.Sometimes it will do memory count, other times just blank screen.
Is it the case that you are turning off the power supply, then immediately turning the power supply back on?
