Thanks to you guys I got this old XT to boot off of floppy. Problem now is that either the hard drive or controller or cables or something is flaky. On occasion the hard drive is recognized and I can catalog it and run some programs out of the root. I haven't had much luck with the sub directories although some will catalog OK just nothing will run from them. More often than not the system does not recognized the HD at all.
Bearing in mind that this XT is the only XT or XT parts I own what do you guys think I should look at ?
Thanks in advance.
Thanks in advance.
