mojorific
Well, I finally got all the parts needed to make a couple of the 2MB EMS boards that James so excellently designed and built. (http://www.lo-tech.co.uk/wiki/2MB-EMS-Board)
Overall, the soldering of components was relatively easy, and as my first at surface mount soldering it took me a few hours to complete one board. A proper soldering setup with a heat gun and liquid solder paste syringe is crucial, as otherwise it would be nearly impossible with the small components. Getting the correct fan speed and nozzle head was critical as well, as otherwise components would literally blow off the board while I was trying to apply heat.
Tested with a Tandy TL/2, and was unable to use the default E000h address (not recognized). Checked all components again to ensure I placed every chip correctly, and then switched to C000h. It was detected by the LTEMM.EXE software properly after that. Memory testing passed.
However, it is only allowing me to use 1.5MB of the boards 2MB. This could be due to the fact that the Tandy TL/2 is expandable to 768k onboard, and there may be some conflict there. Not exactly sure, but i'm not complaining at this point. 1.5MB is plenty of extra ram for this 286 system.
I plan on building a second tonight, and will update on whether the second one behaves in the same way.
Thanks James!!!
Thanks James!!!
