Smack2k
I have a 4GB CF Card I am trying to use with my Lo-Tek CF ISA Adapter (Version 1). Its in my Tandy 1000 TL. On boot, the XTIDE bios loads, but it never sees anything attached. Booting to DOS Floppy and running FDISK says there are no drives. The CF Card is attached to the Lo-Tek via a CF to IDE Adapter that gets power from PSU via floppy power connector.
The solder connections on the 40-Pin connected are fine and I didnt see any issues with them. I ran the CF Card through diskpart, cleaned it and created a partition on it as well. Still not being seen.
Could there be another issue outside bad solder connection I am missing?
