Trixter
Without the exact system to debug on, I can't fix that, sorry. Luckily, the CPU tests are skippable with -s on the command-line.
hello
Just tested my IBM 5150 with MACH20 accelerator card. And it was slower then the Juko v20 I did test some time ago
..have to try my 286->486 cpu in the MACH20 card .. soon!
Trixter - question. Where do we place new measurements ?
And, do you have any plans , regarding how many different computers the database should consist of ?
/cimonvg
I'm not sure if this is a bug or not, but I ran the test on my Sony PCV-LX800 (upgraded to a 1 GHz Pentium III) and it appears to be a lot faster than Tiberian Fiend's K6-2.
MemEATest=54924
I have noticed a bug, in that the program is seeing the 1 GHz Pentium III has a 933 MHz processor. The results I posted are ones I edited the CPU speed in to be correct for the Sony, however I have a feeling the problem is the program is seeing the speed as 133*7.5 for 997.5 MHz but then is reporting as 933 MHz as 997.5 is a odd result, but the 1 GHz Pentium III with a 133 MHz FSB isn't really 1 GHz.
Cool! I've added it to the database and will publish in a new release this weekend.
Hello - strange. The 5150 motherboard is flawless with a v20 or the MACH20 (with original 80286). But with a Inbard386/pc (cpu:evergreen 20/60) or the MACH20 (with cpu "make it 486") the PC only starts with "beeep bep"
/regards cimonvg
