In case anyone's interested in an update/review, my box-o-keyboards came in:
Good Points:
The packaging job was pretty minimal (they just taped cardboard over the open end of the tray), but it's a good sturdy tray so everything was fine. The last keyboard at one end had some keycaps popped off, but no harm no foul, they just pop back on.
The boards are very light despite their depth (Don't buy these if you want a low-profile keyboard, they're a good two inches tall), and they have a nice easy 0.10" pitch pin plug on the end of their ribbon cable so they should be simple to interface to a breadboard. Would be nice if the ribbon was slightly longer, but that's nitpicking. When it comes to "feel", the keyboard mechanism is your standard Hi-Tek, so it feels pretty clattery, but could be worse. (It's nicer than a Commodore keyboard that uses those conductive pads, for instance.)
Not so good points:
I mentioned the keyboard is very light; these were intended for a very cheap computer and it shows. The keycaps are pretty thin plastic and they pop off maybe *too* easily. Here's a picture of the back of one next a TRS-80 Model I keycap. Notice how the plastic is twice as thick on the M1. I think despite the thinness these *may* have double-shot legends on the top, you can see a darker gray plug inside the very tip, but it's not a complete double layer like the M1 key is:
The stems *are* the same size as a TRS-80, so the keycaps are compatible:
That said, I don't know how useful parts from this would be for fixing an older Hi-Tek.
The other reminder I'll chuck out there is that because there are so few keys there are a few gross compromises in the layout. The worst is undoubtedly how the quote keys and question mark are mapped to FCTN+I through O; that might get old after a while. On the bright side across the whole boartd there are legends silkscreened for a pretty full character set (front/back slashes, tilde, pipe, curly and square brackets), so if you don't mind needing that second modifier key you should have no problems using it as a keyboard for any application that wants the full ASCII gamut. One bummer: no ESC or dedicated BREAK key.
Anyway, now I need to decide what to *do* with one...
