Taht board is covered in leaked electrolyte. How is the battery area? Have you removed the old battery.
You need to wash that board extensively to remove the electrolyte residue which has leaked out of all the caps. Yes it will need a recap but first a washing. I recommend your home dishwasher if you have one.. add automatic dish detergent as it has anticorrosive properties and run the cycle (WITH NO HEAT DRY!!!!). Thoroughly dry before attempting to power on. Some people have gotten them to work for a day or so after this (just to test the board). Which may give you an idea if it functions.. But yeah at the end of the day if the board is salavageable it will need a recap. PM me if you need more info on any of what I mentioned.
And Welcome to our Forum!
You should update you avatar area to display where in the world you are located.
You need to recap the entire board before you go further. That IC you took a picture of also needs its legs resoldered with fresh solder to get rid of the corroded junk, along with any other similar damage you find.
