MacBook Air M1 doesn't detect USB Floppy drive
gferluga
My MacBook Air M1 (Apple pro lessor) doesn't detect an external USB Floppy disk drive.
The sysinfo (hardware level) shows the drive:
USB Floppy Drive: Location ID:0x00120000
Connection Type:Removable
Manufacturer:Y-E DATA
Serial Number:Not Provided
Link Speed:12 Mb/s
USB Vendor ID:0x057b
USB Product ID:0x0000
USB Product Version:0x0703
Power Allocated:2.5 W (500 mA)
But at software level not.
diskutil list
Doesn't show the drive.
Could be related to macOS Tahoe 26.2?
Thanks in advance.
I'm pretty sure I read that macOS dropped support for USB floppy drives several years ago.
Everything that comes up in a web search claiming it's possible is from 3 to 10 years ago.
Yes. There is a floppy inside. I'm curious if Greaseweazle or FluxEngine or KryoFlux would make the job...
The current OS is not going to support any floppy compatible file systems. What kind of file system are you trying to access: HFS, MFS, FAT12/16? If the former, perhaps try installing hfsutils (is it Tahoe compatible?) MFS won't work with a USB floppy. I don't think FAT works either, I used an older pre-USB machine for it in the past. So, you are right; the drive exists and can be seen from the OS, it just cannot read from it.
...and now I'm off to eBay.
In case it's helpful, here are the drive details of the drive I tested with:
TEAC FD-05PUB:
Location ID: 0x02110000
Connection Type: Removable
Manufacturer: TEAC
Serial Number: Not Provided
Link Speed: 12 Mb/s
USB Vendor ID: 0x0644
USB Product ID: 0x0000
USB Product Version: 0x0000
Power Allocated: 2.5 W (500 mA)
I just tried another drive too, with the following details:
FlashBuster-U:
Manufacturer: Y-E DATA
Link Speed: 12 Mb/s
USB Vendor ID: 0x057b
USB Product Version: 0x0312
It was a little strange, and at first I thought it didn't work, but I ejected the disk and tried another and it worked fine, and then I went back to the original disk and it worked fine too, so maybe the mech was just stuck.
Also this drive, using both of the exact same floppies, shows a floppy icon in MacOS 26.2, and the other drive just seemed to show a generic grey icon for an external drive.
This drive was one of those marketed towards the original iMacs where you could replace a plastic panel in the drive with one the same color as your iMac.
I just tried this on my Mac mini M4. It sees a FAT formatted floppy disk just fine.
Strange, I tried two functional USB drives on an iMac with no luck so I ended up digging out an old 68k laptop which read them with no issues. Obviously the FAT filesystem is supported with USB HDDs and UFDs, I just had no luck myself via a USB FDDs. It may have been the old version of OSX I was using, I didn't try on a new OS.
