What you _could_ do is…
1) NEW ALL : OLD “100.LOAD.PGM”
2) load RBUG.SUB 1st, then the rest off your subs, with Load.PGM
3) CALL RBUG. Load RBUGs PC with the address of the small Asm
routine you’ve previously created in cartridge RAM
to OPEN a
Binary File on whatever your connected storage is & starting with
>3FFF Write the contents of SYSRAM to file, decrementing your
SYSRAM counter by 1 after each Write until >2000, inclusive.
Now you’ve got the SYSRAM binary image file on your PC for your
Flash pgmr. Depending on the pgmr, you might want to REVERSE
(.EXE) the image - Jeff can presumably advise about that.
I bet you a nickel it’ll work - At least until its time to FLASH your ROM;
Since I have no idea what’s on the inside, my suspicions there are…
undefined.
The file routine should be quite small - Small enough to load and run
by hand with RBUG, so no headers etc needed.
