pianoman72
Hello,
Would anyone happen to have a copy of the M-209 motherboard manual? It is a 286 motherboard, with a Harris 20mhz CPU.
I cannot seem to find a physical or digital copy anywhere, after searching online extensively.
I mostly need it to get the exact name of the expanded memory driver that was included initially (along with its command line parameters), which is required for using its hardware C&T chipset expanded memory.
Thank you to all.
Thank you to all.
