| VCF SoCal | Feb TBD, 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
| VCF Latam | TBD, 2027, | Bahía Blanca, Argentina |
| VCF Pac. NW | TBD , 2027, | Tukwila, WA |
| VCF Southwest | Jun 25 - 27, 2027, | Westin Dallas Fort Worth Airport |
| VCF Southeast | Aug TBD, 2027, | Atlanta, GA |
| VCF West | Aug TBD, 2027, | Mountain View, CA |
lol that's interesting but nope not from me. I'd be curious who it may have been though.
...Several arcade video games also used laser discs. Dragon's Lair was the most popular one I'd like to find. I *think* that "old" 3d video (video was projected to the center of the round console) game .. trying to remember the names, one was a cowboy shooter and the other I think was a time traveler game. Interactive video footage, mostly so you could try and hit the "fire" button before the computer.
Work has resumed.
Initial testing was to see what the voltage rails were like without any load. +5, -5 and -12 were in spec but +12 is only 11.2v until I attached a hard drive and that oulled it up to 11.8v (still low but just within limits). At the very least though the PSU is behaving well enough to resume testing.
Starting with the backplane I found and removed two shorted tantalum capacitors on the -12v rail, clearing the short we had previously found. When reinstalled however all but the +5 was coming up immediately, until another tant that had not been reporting itself as shorting blew itself apart. I checked all those tants. Why did you decide to still give out?? Removed that one and tried again. All four voltages came up but suddenly -12 vanished again. Sure enough, another tant on the board had shorted out. I'm amazed the PSU is not kicking out with these near 0 ohm shorts. Removed it AGAIN, let the PSU run with the backplane and a load on the power rails and so far things are stable so I think we got them all.
I only briefly checked the three ISA cards but it appears the SBC and VGO boards also have ground-to-rail shorts. I'll deal with those once the backplane stops screwing with me.
We could try reading back with the DAata I/O 29B + Unipak 2 but I've never figured out how exactly to make it work.
to check the firmware revision of the unipak press, select e f start and note the output.
fa62 05 **
while you're at it press, select b 2 start and note the output, that will check the main 29b unit firmware revision which went up to 6.
70b3 64k 29b v01
