Micro House Technical Library cd
Mr. Horse
USA:OHIO
Does anyone know were I can get the full version of the Micro House Technical Library cd, not the demo or book. the cd and extra libs that later became the th99?
thanks.
Actually, yes. I have one. May not do much good, though, since a specific version of the install floppy is required, and I haven't located that yet, nor have I located the NetSentinel hardware key; this was in a whole box of CD's from a computer reseller, and there are some other goodies in that box that I really need to go through, like old Seagate Backup programs, Cheyenne backup, Compaq CD's, WIN95 A&B CABs, and others; I have a whole box of miscellaneous hardware from that reseller, and the NetSentinel key might possibly be in there somewhere. Here's the contents of the 'version.197' file on the CD:
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³  VERSION.197                                                ³
³          ³³                                                 ³
³  QuarterÄÙÀÄÄYear                                           ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
This is the 1st quarter 1997 version of the MTL on
CD-ROM.
This CD-ROM must be installed from the 4th quarter 1996
installation floppy disk.  Installation floppy disks from
previous quarters are not compatible with this CD-ROM.
Micro House International +1 800-926-8299
                          +1 303-443-3388
³    Description of directories and files on this CD          ³
Directories marked with a * contain files that are only
accessible by the MTL engine and are of no use to you.
Directories marked with a + contain files that may be
useful to you.
\C                 * Hard drive controller card documents.
\DRIVERS           * Software and drivers.
\DRIVERS\HP        + HP LJ4 Printer Drivers.
                     If you are having trouble printing from
                     the MTL to your HP LJ4 printer specify
                     this directory as the "diskette provided
                     by the manufacturer" in Windows printer
                     setup.
\DRIVERS\NETWARE   + The latest DOS/Windows Netware Drivers.
\FCCID             + FCC ID Look Up.
\INDEXES           * Databases and indexes used by the MTL.
PLEASE SEE THE HELP TOPIC "USING THE KEY" IN THE MTL HELP FILE
FOR DETAILED INFORMATION. PRESS F1 WHILE IN THE MTL FOR HELP.
CALL MICRO HOUSE PRODUCT SUPPORT IF YOU CAN NOT GET THE KEY
TO WORK AT 303-443-3389.
\KEY               + NetSentinel(tm) Protection key utilities.
                     If you have a BEIGE key or a NETWORK
                     version then use these utilities.
 DOS      TXT      + How to use the key with DOS (or Windows)
                     and IPX or NETBIOS
 DOSMON   EXE      + Network monitor program for use with DOS
                     and IPX or NETBIOS
 DOSMON   TXT      + How to use the network monitor with DOS
                     and IPX or NETBIOS
 FINDKEY  EXE      + Utility to see if the key can be found.
                     For Micro House Product Support use.
 IXSTAT3  EXE      + Utility that returns IPX/SPX information.
 NETW311  TXT      + How to use the Netware Key NLM
 NMONDI   EXE      + IPX/SPX monitor for DOS.
 NMONDN   EXE      + NetBIOS monitor for DOS.
 NMONOM   EXE      + Multi-protocol monitor for OS/2.
                     See OS2MON.TXT
 NSRVDI   EXE      + The Netware Key EXE (for 2.15, 2.2, 3.1x, or 4.x servers)
                     If you want to run the key from a workstation then
                     attach the key to any workstation and load this
                     program on that workstation.  Other users will then
                     be able to find the key on the workstation.
                     If you use this method then DO NOT load the
                     NSRVNI.NLM.  See NSRVNI.NLM below for more information.
 NSRVDN   EXE      + The Windows for Workgroups (or ANY NetBIOS compatible
                     network) Key EXE.
                     Attach the key to any workstation and load this
                     Do not use this for Netware.  Instead use
                     NSRVDI.EXE or NSRVDI.NLM.  Also see NSRVGX.EXE
 NSRVDN   PIF      + A Windows Program Information File for NSRVDN.EXE
                     Run this to launch NSRVDN.EXE
 NSRVGX   EXE      + The Windows NT and Windows 95 Key EXE.
 NSRVNI   NLM      + The Netware Key NLM (for 3.1x or 4.x servers)
                     If you want to run the key from the server then
                     attach the key to the server and load this NLM.
                     MTL users will then be able to find the key on
                     the server.
                     NSRVNI.EXE.  See NSRVNI.EXE above for more
                     information.
 NSRVOM   EXE      + The OS/2 Key EXE for use with NetBIOS and Named Pipes.
                     See OS2.TXT for more information.
 NWIPXSPX DLL      + In order for the MTL to find the hardware key
                     when it is attached to a Novell File Server,
                     the NWIPXSPX.DLL file must be in the default
                     Windows or Windows System directory.  Use the
                     NWIPXSPX.DLL file that is in the \KEY directory
                     if there is not one in the Windows or System
                     directories already.
 OS2      TXT      + How to use the key with OS/2
 OS2MON   EXE      + The network monitor for use with OS/2
 OS2MON   TXT      + How to use the network monitor with OS/2
 OS2SNTNL SYS      + OS/2 key driver.  See OS2.TXT
 README   TXT      + Additional information on the key files.
 RHPANELP DLL      + Used by the NMONOM.EXE OS/2 program.
                     See OS2MON.TXT
\KEY\SYSDRVR       + Port Drivers for Sentinel(tm) Protection key.
                     These port drivers allow better communication
                     with the printer port thereby allowing the key
                     to work better.
\M                 * Main Board documents.
\N                 * NIC documents.
\NC                + NetCom(tm) NetCruiser(tm) trial version.
                     Internet connection package.  Includes
                     free conect time. Run SETUP.EXE.
\REG               * Electronic Product Registration files.
\SYSFILES          * Miscellaneous files used by the MTL.
\UTILS             + Miscellaneous Micro House utilities.
 COMPRESS EXE      * Use only at the advice of Micro House
                     Product Support.
 DRIVEPRO 1        + Database file used by MHSETUP.EXE
 DRIVEPRO 2        + Database file used by MHSETUP.EXE
 DRIVEPRO 3        + Database file used by MHSETUP.EXE
 DRIVEPRO 4        + Database file used by MHSETUP.EXE
 DRIVEPRO 7        + Database file used by MHSETUP.EXE
 DRIVEPRO 8        + Database file used by MHSETUP.EXE
 ESCAN    EXE      + Scans an IPX network for Ethernet cards.
 FLAG     BAT      + Turns your DOS prompt into an American flag.
 IDECACHE EXE      + Turns on/off IDE look-ahead cache.
 MHESDI   EXE      + Returns information on ESDI drives.
 MHIDE    EXE      + Returns information on IDE drives.
 MHRESTR  EXE      + Restores information saved with MHSAVE.EXE
 MHSAVE   EXE      + Saves vital system information to a file for later use.
 MHSETUP  EXE      + Simple CMOS setup utility.
 MHSYS    EXE      + DOS Sys replacement.
 README   TXT      + A description of MHSETUP.EXE
 UNCOMP   EXE      * Use only at the advice of Micro House
                     Product Support.
\V                 * Miscellaneous I/O card documents.
³### END OF FILE ###                                          ³
³Copyright(c) 1997, Micro House International with            ³
³all world rights reserved.                                   ³
This is what it looks like:
I have the full Microhouse Technical Library Hardware Support 1995, with NetSentinel hardware key, and installation disk originally purchased in the mid 90's for over $1000.
Were there versions of this that did not require a dongle? I purchased the full set in 1999 when working at a computer store as a tech. I don't remember needing a dongle to use/install this. When I left the store in 2000 of course the software stayed, having been purchased by the store.
I believe there is a version of it labeled/branded "Support on Site for Hardware". I have a set of thee discs, 1st quarter 97. Install was off CD iirc and no dongle. It's got Micro House and Ziff Davis Interactive branding.
What is the newest environment this will run under? Doesn't work in Windows 10 - complaints that 16-bit mode is unsupported.
