SuperMax
I vaguely remember that the bus on E85 was the same as on its pro--totype, including even inch based pitch. I might be wrong on that, but E85 is certainly a rare species on this side of the ocean. Pro 350/380 should be much more common
Cool. What part did you plan for physical connector? I realized later after writing that those board have weirdest jaw-pinch connector type. I would certainly be willing to sacrifice my color bit map board to de-solder the original DEC part connector, but that would not be a sustainable plan for a (limited) mass production. The main section of connector seem to be equivalent to ISA-8, but second section is shorter and closer to main than on ISA-16.
That would be very intriguing with respect to existing pro software that was using graphic capabilities of pro. But maybe from the point of view of available software it would better to be compatible with DVK/BK graphics. I was enjoying the native version of LAND for E85 on my 350 though
forced to upset
I do not plan to produce ready-made controllers yet
because in principle I do not know where to get the connectors
also now I do not have complete information on the operation of the bus in DECPro
also I don't have DECPro
i only have E85
i am planning to make PCB for experiments with AZ for firmware development
