Great news!
in our team is now an RSX specialist and he has successfully written the AZ driver for RSX-11M!
AZ disk image with RSX-11M-PLUS V4.6 distribution.
The AZ device in the system is called DA.
The device driver is located in the [3.54] directory.
It is vectorized and can be freely transferred to another RSX-11M-PLUS.
The driver determines the size of the disks by itself without the participation of HRC.
Distribution changes compared to the original:
* fixed errors detected in HELP files
* BOO added DA device support
* in the BOO program, when performing a hardware boot (/ HW option), a reset is performed before transferring control to the hardware bootloader (this allows you to boot any systems in this way, and not just RSX of older versions for which the option was added)
* the BRU program has added a rights check when recovering to a mounted disk, so that a simple user cannot recover files where he should not have access
* FLX marked DA device as valid for RT-11 file system
* added setting of AZ11 device type for DA device in HRC program
* in the MCR program for the DEV / LOG command, the date alignment is made for a more pleasant display
* in the MCR program for the CLI command, the / LGO option was renamed to / LOG (as written in the documentation and HELP file)
* in the RMD program, the display of free space for large disks on the VT52 terminal has been fixed
* added support for DA device in SAV program
* in the SAV program, when the VM3 processor is detected, the Q-Bus is set in the parameters
* added permission check for the opened image file in the VMR program
* fixed a bug in the generation routine that would crash if the system does not support dividing the instruction and data space
We also continue to work at the AZ BK
The enclosure specialist has developed an excellent enclosure
